My xbox 360 (newer version) won't turn on?
I mean look, I plug it in and when I touch the power button it makes the beep turning on sound but it stays off. Same with the disk input. I don't use HDMI I use the vid 2 for the TV.
Hi, it might be that the cables are faulty. Can u see the xbox showing the green rings? An hdmi cable is not that costly now, so see if u can get one and test with hdmi. Write back on what u did. Good luck.
这个答案有帮助吗?
It doesn't show any green rings, and I'll try to get an hdmi cable as soon as I can. I'll get back to you when I try it out
It didn't work with the cable so I had to go send it in for repairs. Apparently somehow it was wet on the inside? (sorry for the late answer)
Common issue with "no power" is a usb port has bent pin and grounding. Visually check your Xbox 360 USB ports. None of the center pins should be touching the casing or outer area.
这个答案有帮助吗?
All USB Ports are fine, but I've noticed that after I plug in the power and disconnect it there is a delay in the power box.....anything about that?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,394
