跳转到主内容
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 个问题 查看全部
glass replacement of iPad mini-reg
my iPad mini glass broke down due to a fall.in india the store ask 17000rupees where as mini costs 21000only.
kindly guide
rao
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The issues with the repair is there is an intensive solder job that must be done to remove a part of the digitizer connection flex and add it to the new digitizer screen. Its very possible and easy if you know how to use a typical solder station and hot air rework station.
这个答案有帮助吗?
得分 1
添加一条评论
just be careful with the process, it can go horribly wrong if you are inexperienced. look at some of these photos of how badly it can be done.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RAMA RAO 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 3,864
