跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Digitizer problem, one area not working
Hi, I have an Iphone 4S that has one certain area of the screen sometimes not responding to touch, the area is "4,5,6" on the keypad when trying to dial a number.
Does anyone have any solve around this?
Thanks,
Mykel
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Yes. You have a broken digitizer, so replace the display assembly.
iPhone 4S Screen
iPhone 4S Screen图片
产品
iPhone 4S Screen
$34.99
这个答案有帮助吗?
得分 1
1条评论:
i have repaired over 100 phones, just ran into a problem where a strip of the digitizer is not working. the problem occurs from Q to P on the keyboard in portrait mode. i have an iphone 4 assembeld with no screen and i use it to test screens. the screens i am using work fine with the test phone. upon inspection of the 4/s i see no problem areas. any suggestions? also i tried to hard reset/ and hard restore the phone with no success after updating.
完成的
添加一条评论
最有帮助的答案
I had a similar problem with a 3gs. I tried a couple of spare screens but could not get rid of the dead spot. A narrow vertical area corresponding with the letter I when the keyboard is on screen. I put the main board under my microscope and found small traces of what looked like solder splashes on two of the pins in the digitizer socket.
这个答案有帮助吗?
得分 1
添加一条评论
i put a new digitezer on the phone and still some of the letters don't work in portrait mode , turn the phone in landscape all the keys work ...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mykel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 2,311
