跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
Do you really have to remove the battery to replace rear camera?
I have ordered a replacement 4S rear camera which will hopefully fix my 4S. In reviewing iFixit and other tutorials for the repair, all mention first removing the battery before proceeding.
Is this actually necessary? The battery doesn't seem to physically obstruct anything with the camera replacement. Perhaps it is necessary to cut power to the phone components?
Thanks,
Steve
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Not necessary. Apple Technician Guide for iphone 4 has the correct procedure. battery is not removed. Actually, the battery MUST NOT be removed for safety reasons. once the battery is removed it MUST NOT be reused. So ifixit disregarded safety warnings, again.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
it's for safety, you don't physically have to. but you dont want to short cut anything else
这个答案有帮助吗?
得分 1
1条评论:
Thanks for the reply iwillfix, that makes sense to me. When you pull the EMI shield, it's probably easy to short something on the board.
I guess you could also just pop the battery connector up and disconnect the power only. Removing the battery is no big deal, but I figured if my battery happens to be glued down really well then I could avoid prying it off.
完成的
添加一条评论
添加你的答案
madmaxmedia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 172
