跳转到主内容
加入维修社区 - 创建账户
第一代苹果iPad 配备有WiFi 提供16.32或64GB 型号为A1219 维修是直接的不需要任何加热。
broken volume control cable
My ipad was dropped and the digitizer smashed around the top right. The screen was working so I removed the digitzer to replace it. Upon removal I saw that the wire to the volume control was broken. The screen now has a 1.5 inch band at the top with no image showing. Are the two things related? Is the screen now toast? Can the volume control cable be replaced? Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hi joseph,
I don't know if the two issues are related.
Based on the teardown (step 11), both cables are very close to one another and on the same board. You might want to check if the display cable is still 100% attached/connected on both ends. Based on the dead area of the LCD, it could be that the connection got loose on one side.
In regard to the volume button, I would try to solder back the one wire that is broken. Or, if this is not possible, you might want to buy a replacement unit like this.
Steffen
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 139
