跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Silver Power Button Missing Spacer? (iPhone 4s) - [SOLVED]
Addendum to the original post:
Here is a screen shot of the bottom of the lock button. I'm wondering if there is supposed to be a spacer placed in the center hole?
----- Original Post
Working on an iPhone 4s. I followed the guide here on iFixit.
iPhone 4S Power Button Replacement
I unscrewed and removed the old power cable (step 26) and replaced it with a new one. Note, before installation I depressed and released the contact on the round power contact and it clicks.
However, after screwed back in, when I press and release the external/silver power button I can't hear click or feel it make contact with the round button on the flex cable.
I also tried it using a good flex cable out of another phone that I'm working on and no difference.
Maybe I'm missing something. I pulled out the silver power button, put it back in with the hinge down and simply screwed the power cable back on. Is there some way that I need to adjust the swinging hinge on the power button? Does the black connector with the two screw holes on the power cable need to be tilted in or something when putting it back in place?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
[SOLVED]
I keep a roll of copper that has adhesive on one side. I cut off a little square and stuck it in the countersunk hole on the button. Once assembled I worked the button left and right slightly. I figured the adhesive would hold it in and since copper is really malleable it would mold itself when the button is pressed and released.
Works perfect. Just wanted to post in case someone else finds themselves in a similar situation.
这个答案有帮助吗?
得分 2
1条评论:
How thick is the copper? Where did you get it?
完成的
添加一条评论
Bend the hinge so that the button on the flex cable are higher than the screws on the sides, and remount it.
这个答案有帮助吗?
得分 1
4条评论:
The hing is sitting flush. If I bend it out, wouldn't that cause more of a gap between the silver power button and the round button on the flex?
完成的
No bend the hing just a little bit
完成的
You could also try to remove this cap the orange one and replace it with a new one
完成的
Yeah, I worked with it till early a.m. and that cap came off. I have a new flex cable coming.
Oh, did you read my addendum at the top about the spacer?
完成的
添加一条评论
添加你的答案
Country Computer Service 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 6
总计 1,605
