跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Stripped SSD Retaining Screw - Options?
I accidentally stripped my ssd retaining screw while changing my SSD to a bigger one. I want the thing out, what are my options?
Also, is it possible to get a replacement screw?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Did you pull the head of the screw off or just stripped the slot?
You'll need to drill out the rest of the screw if you pulled the head off. Make sure to mask off the area so none of the metal dust gets inside.
If you stripped the slot you may have used the wrong screw driver bit. Now you'll need to get a jewelers drill to grab the outside edge of the head to unscrew it.
Getting screws can be tricky, often you'll need to buy a gross (20 - 50) or a set like iFixit sells.
- Good Luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pozzo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 771
