跳转到主内容
惠普 “Mini”系列的小型上网本维修手册。
Why won't it boot up
Can't get my HP mini to boot up. Won't boot in safe mode either. Also, can't get it to access restore discs from external DVD unit. Starts the boot just fine but once the HP logo disappears, it stops and I just get a faint Microsoft crawler across the bottom of the screen
I've tried the repair screen but that goes as far as my boot. Any thoughts from out there?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Well if u can boot bios verify that u still have a working hardrive by checking if bios still detects it, after that u can try to use a windows cd to do a repair on it, maybe some sistem files are corrupted, if this fails try using a linux live cd to run some hardware diagnostics ( if u have 2 many bad sectors it might not load windows properly ).
If hard drive is ok and repair doesnt work u will have to do a clean instal .
这个答案有帮助吗?
得分 1
添加一条评论
You need to go to bios settings and restore your computer then it will start working fine.
Note - while you will restore your computer. it will uninstall all softwares from your computer. so please make sure about that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John White 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 538
