跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Is PC2-6400 compatible with EMC2133 iMac?
Hello!
I wanna upgrade my iMac EMC2133 original configuration and add some RAM. I found some ram stick of DDR2 PC2-6400, and those are usually backwards compatible in most mainboards, but i don´t know if this is the case. I know that it uses 667 ram, but it will work with 800Mhz ram?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Won't work you have the wrong machine for that type RAM. You'd need a 2210 iMac8,1 for the RAM you found.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
this (a) does not answer the question and (b) is not true - see the other answers, below, that show this does work fine.
完成的
添加一条评论
It does work. I found confirmation of this on a different site and have just installed some. Works perfectly.
这个答案有帮助吗?
得分 1
1条评论:
it's true , it works flawlessly! I succesfully upgraded my a1224 and it's now running 2gb of 667mhz together with another 2g of 800mhz pc2-6400 and they seem to coexist with no hassle at all!
完成的
添加一条评论
Also, this site works EXTREMELY well for specs on all Macs and iDevices.
http://everymac.com/ultimate-mac-lookup/...
You can look up each Mac, down to serial number and then open a large list of specs.
For your iMac EMC2133
http://everymac.com/systems/apple/imac/s...
Scroll down a bit and you will find this info:
RAM Type: PC2-5300 DDR2 Min. RAM Speed: 667 MHz
Details: Supports 667 MHz PC2-5300 DDR2 SDRAM (200-pin SO-DIMM).
Standard RAM: 1 GB Maximum RAM: 6 GB*
Details: 1 GB of RAM is installed as a single SO-DIMM module.
*Apple officially supports 4 GB of RAM, but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
In the US (and many other countries), site sponsor Other World Computing sells memory -- as well as other upgrades -- for this iMac.
In Canada, site sponsor The Mac Market sells memory and other upgrades for this iMac.
In Australia, site sponsor RamCity sells memory and other upgrades for this iMac.
In Southeast Asia, site sponsor SimplyMac.sg sells memory and other upgrades for this iMac.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joaquin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 14
总计 2,269
