跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
iPhone 5 only charging on one side?
The other day my iphone decided to start only charging on one side... It isn't my cable (I have tried 4 and they are all the same. They will charge other iPhones fine). I have replaced the lightning connector in my phone to no avail.
If anyone has any solution to this it would be greatly appreciated. I do not want to swap my phone at an Apple store, as it is jailbroken.
Thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
7条评论
Mine started doing the same sort of thing.....it has gradually gotten worse and worse.
Bought the proper Apple brand cable and some off brand longer USB/Lightning cords and wonder if that caused some sort of mechanical wear to the internal connecting fingers that rub against the lightning connector tab...
Not really much help for an answer but I have decide to change out the lightning connector.
完成的
Same here. At first, it wasn't charging at all on any cable. Then I did a reboot and it started charging but on one side only.
I'm calling Apple and I suspect they'll swap out the phone. You shouldn't have to have a phone that only half works!
完成的
Unfortunately mine has been doing the same thing for several months. Just about the time that I had upgraded from jailbroken iOS 6 up to the beta iOS 7s. I have an old 30pin clipusa car passthrough mount that has only a forward orientation and thus with the 30pin-lightening adapter can only mount the iPhone 5 forward. This is a problem for me as the iPhone will only charge from a backward orientation. No physical or water damage at all. One day it was working, the next it was not. Pretty crappy. I also tried several cords and adapters just to see if it was the hardware and each and every one will only work in the 'backward' orientation.
完成的
OK - so here's a low budget fix. The graphite pencil fix.
The port on the phone can be cleaned out with a wooden cocktail stick. I spritzed a little Maplin £3.99 electrical contact cleaner in there for good measure.
That leaves you with the cable itself. You'll likely see that one of the little gold pins has gone black through oxidization on one side of your cable. This seems to be a weakness of the lightning design.
All you need to do is to colour-in the gold contacts with a normal graphite pencil, then wipe the excess graphite of by using the rubber on the other end of the pencil! Hey presto. The cable works again on both sides!!
This works because graphite is electrically conductive and slightly abrasive. So it cleans off some of the oxidised gold plate and replaces it with a new conductive layer of graphite.
完成的
I too have a problem charging iPad Pro !!! An really expensive problem...
All the cables I have including original Apple bought recently , are useless. They are not recognized by the tablet.
Fortunately I still have an old cable that I bought time ago but did not use it regularly because it wasn’t long enough. By accident I did ‘t throw it in the garbage.Desperate I searched for a solution to charge my iPad Pro fo witch I payd a lot of money. I take my old short cable and surprise. A little lightning apeared beside almost empty battery icon. . All those brand new cable recently bought did nothing. The 2 years old worked. Then I went to a store and asked if they still have lightning cables from two years ago. They flipped through the warehouse and gave me the last three pieces they had. Surprise again . ALL HAVE BEEN RECOGNIZED BY THE IPAD .
Conclusion ? Either the old cables have something extra or maybe the recent production one has something missing .
1 hour ago by Dni Tm
完成的
显示更多的2条评论
添加一条评论
7个答案
已选择的解决方案
I noticed the connector metal parts were blackened or oxidized and it would only charge in one direction. I called apple support who suggested a factory reset -I was pretty unwilling as a factory reset is quite a bit of work and my iopd touch 5th gen was jailbroken -the factory reset would force an upgrade to ios7.0.4 for which there is yet no jailbreak.
I decided to take a chance and rinsed off a steel wool SOS pad thoroughly and very carefully attempted to clean the metal oxidized/dirty connectors. After a few minutes I thoroughly dried the connector and plugged it in. Success! both ways now charge the touch.
It should be noted that I took some risk in doing this as I could have damaged the connectors further but luck and patience paid off.
This was a 5th gen ipod touch purchased in December 2012 with the original lightning connector -hope this helps someone.
这个答案有帮助吗?
得分 6
5条评论:
What are the connect black parts and where are they located ?
完成的
No idea but I have the lightning charging port all memorised in my head.
There are 5 pins on the bottom of the charging port. There is not 5 pins on bottom and top just bottom.
The double sided connection contacts on the lightning cable is so that you can do reversible plug both sides in.
Sometimes the pins in the charging port are dirty, corroded or actually blocked by debris.
Various ways of cleaning this is carefully cleaning debris out without pushing the pins left to right. These pins actually push downwards from the pressure of the lightning cable going in.
Isopropyl alcohol works well too make sure 99% or more for best results on cleaning the pins specifically.
I use either striaght tweezers or a toothpick if you don't have one of those.
完成的
Thanks. The pencil actually worked. My cable has the 4th metal contact that has been worn down for some reason but I've always just bough new ones. I cleaned it, very
完成的
I looked at the connectors before but they appeared to be clean. However when I used the pencil method, the cable worked on both sides again! Great solution; thanks a lot.!
完成的
How is the pencil method?
I can’t understand also undestand thr pins, etc without photos
完成的
添加一条评论
It is just dust in the connector, Careful pry it out with a needle without damaging the connectors and you're good to go. See this very often with the lightning connectors from iphone 5/s/c
这个答案有帮助吗?
得分 2
2条评论:
Agree. I did this as well with a small soft brush and works. Massaging the cable a bit near the tip may also help and make sure you put the connector in the port rather firmly once it only works at one end;.
完成的
This is it the problem, a lot of dust into the connector. I used a toothpick and took out a lot of dust locked on the bottom.
完成的
添加一条评论
I assume what you mean is that the lightning connector has to be inserted in a certain orientation. If so, put a dot on the side that needs to face up.
这个答案有帮助吗?
得分 0
1条评论:
But... really!? And put a dot on the cable FOR YOU this is a solution?! :D
I would really quick call Apple for assistance, you can jailbreak the next one...
完成的
添加一条评论
If there's dust/hair/lint in the connector (and there almost certainly is; I've seen Apple Geniuses fish an enormous amount of junk out of those connectors. Sticking a Lightning plug into the socket just packs the gunk down into the socket until you can't charge at all), then it's much safer to get it out with a plastic tool, which won't carry a static charge. Like this one:
Detailing pick
I wish Apple would come clean about this issue, because this is a problem that can occur with normal use. If you stick your phone in a pocket or purse, small particles and lint will go into whatever opening the phone presents. Isn't that how everybody carries their phone?
Unfortunately, Apple's support note has a 'refer to qualified service personnel' disclaimer:
"If your battery doesn't charge, or if your device shows a low-battery image, black screen, or "accessory not supported" alert, follow these steps.
Inspect the connector at the bottom of the phone:
Make sure that there are no bent pins in the connector.
Make sure that the connector is free from debris.
If there are bent pins or debris, please contact Apple Support.
Otherwise, continue troubleshooting."
http://support.apple.com/kb/HT1476
这个答案有帮助吗?
得分 0
添加一条评论
Mine has started to do this just recently when using the plug adapter, but as soon as I use the cable in my cars 12v cigarette lighter it works both ways, I've also tried other cables too genuine and non genuine ones, and they all seem to be doing the same thing only working one way when plugged into the genuine adapter but working both ways when used in my car! I'm so confused and so are Apple! Any suggestions as to what this may be would be great :)
这个答案有帮助吗?
得分 0
添加一条评论
Answer found! If you have ruled out it being the cable and the charging flex cable then the charging connector on the logic board is dirty. Give the pins a very light scrape with a small flat head screwdriver and then a quick brush over with PCB cleaner or isopropanol - this should solve the problem. This has worked on two of my recent customers phones. *disconnect battery first and allow to dry properly before re-assembly.
这个答案有帮助吗?
得分 0
添加一条评论
It happens when you change the dock connector assembly and you forget to put back those two tiny spring washers underneath the charging port itself unfortunately you can't buy them as spares u need to find alternative washers this will definitely solve the problem
这个答案有帮助吗?
得分 0
1条评论:
What 2 tiny spring washers?
完成的
添加一条评论
添加你的答案
Ryan Caird 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 15
过去 30 天: 77
总计 89,836
