跳转到主内容
加入维修社区 - 创建账户
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Unit not heating up.
Am following the boiler step by step guide. Checking the leads for voltage; there is none. However, when the steam button is on, there is voltage. Question; what is the diagnosis. I determine the boiler is not deficient. Could it be a switch, fuse, or thermostat? Please advise.
Regards,
Brett
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Check the boiler heating element for continuity as well as the fusible link attached to the top of it. If either is open that's your problem, and hopefully it's the fuse as that's much easier/cheaper to replace.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 899
