跳转到主内容
SanDisk Ultra Plus 256GB 2.5 SATA III SSD fit
My PB G4 is overheating and I want to replace the hard drive with the SanDisk Ultra Plus 256GB 2.5" SATA III SSD. It seems like a relatively complex procedure and I am not sure I am up to it. Finally, I do not know if the SSD will fit in the PB G4.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Not a good idea your machine can't use SATA drives it's' UltraATA, so you'd have to find and fit a gender-bender (not even sure such a thing exists) if it did, the drive may have problems writing that slow, causing freezing and hanging.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
Great advice and wonderful contributor! Thanks!
完成的
添加一条评论
Accepted with thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dave Dorn 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 7
总计 372
