跳转到主内容
加入维修社区 - 创建账户
The Super Nintendo Entertainment System (SNES), or simply the Super Nintendo, is a 16bit gaming console released by Nintendo in 1990. The Super Nintendo was one of the best sellers of its time and still has a large fanbase today.
Why is my picture distorted?
I brought my snes out of storage after a few years. I hooked it up properly, inserted super mario world, turned it on and I could clearly read the words "Nintendo presents" but when it went to the next screen the picture looks jumbled-like a jigsaw puzzle that's missing pieces. I tried another game and it was the same. I cleaned the games and the console. I tried 3 other t.v.s and it's the same. I have audio, but a jumbled picture. Any ideas why, or how to fix it would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
9个答案
最有帮助的答案
Could the audio video cable be bad? Gamecube/N64/SNES share they same cable so it shouldn't be too hard to find another one to test your connection.
这个答案有帮助吗?
得分 2
添加一条评论
I have a similar problem with a distorted, pixelated picture. The problem is that a hair managed to sneak it's way into the connector and then snapped off when I tried to remove it. I have yet to open mine up and repair it, but I think it will be relatively simple when I find the hair node.
The important thing is to troubleshoot. If you think it's the connector or cable, try using the coaxial output. If it doesn't power up, you have other problems. Start at the easiest to replace - not the likely culprit.
这个答案有帮助吗?
得分 1
1条评论:
is the hair in the console or the cart? im having the same problem with 2 different carts of the same game
完成的
添加一条评论
Hi there!
If you see something similar to this
http://mentalfloss.com/sites/default/fil...
even after you have cleaned contacts and eliminante every "hair node" from the cartridge port, you might have a defective RAM or VRAM. A technician with experience in replacing SMD components can replace it for you, if you provide the chip. Hope that helps.
Cheers
这个答案有帮助吗?
得分 1
1条评论:
Hey what did it look like? I have an issue on mine where moving sprites seam to split horizontally, i only have mario paint,and street fighter 2 so its hard to say if the cartridge is the fault
完成的
添加一条评论
I am having the same issue. I just replaced the cable that hooks into the back of the Nintendo and the three different color coated prongs that go into your tv. I'm still just getting the Nintendo presents and then jig-saw. Were you able to figure out how to fix this?
这个答案有帮助吗?
得分 0
1条评论:
I have this problem every now and then but usually blowing into my cartriage and my console fixes this problem
完成的
添加一条评论
I think it might be my cable. Any ideas on where to buy cables? Can I buy cables without buying another console?
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue! I've tried with different cables and had the same problem. I've only tried it with the same HD TV (Toshiba). My N64 and Gamecube work perfectly with the same cable.
Did someone find any solution?
这个答案有帮助吗?
得分 0
添加一条评论
It's the TV they are 90s consoles not designed for HD tvs try on an old square tv
这个答案有帮助吗?
得分 0
添加一条评论
I have a video problem with mine. It doesn't seem to have a complete video jigsaw problem, it affects certain things. I can honestly still play through all of the games. But some things are hard to see. Like top gear, the background, other cars on the track are good, but the car you're driving is not all there. With killer instinct the background is fine, but characters have half of themselves missing. Super Mario world, the boxes and the mushrooms show up in two places on screen which look like if you put them together they would be complete. I've tried multiple video/audio cables, multiple TVs, taken it completely apart and cleaned it. I did check the voltage from my power supply and found that I have more than double the voltage should have. So my immediate problem is the power cable.
这个答案有帮助吗?
得分 0
1条评论:
If you had double the power going in, it's very possible that it melted some of the solder and A peg from a chip might no longer be connected.
完成的
添加一条评论
I have the similar problem but only with some games super mario world plays find but 2 different secret of evermore carts are "jigsaw ish" as was described.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heather 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 92
总计 31,517
