跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
MacBook Won't Boot Up
I have a MacBook A1342 and it won't boot up. At first, I thought the topcase was the culprit, so I replace the top case, and still nothing. Then, I thought the battery was dead, so I replaced that as well. Still nothing. When I plug the computer into the charger, the MagSafe illuminates with a green light, but when I try to boot the machine, nothing happens. The fan doesn't even spin. Anyone have any advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Even if you have a strong green led on the AC adapter tip the magsafe DC in board could be the culprit. Did you test it ? Also did you try a known working AC adapter ?
If you have a multimeter find the two power pads (left side of the top case connector) and with the multimeter settled to DCV/20 put the black probe on any logic board screw for ground and the red prob on one of the power pads. With the AC adapter connected you should get 3.42 volts one one pad and 0 on the other. Any other reading means something is wrong with the power line. Disconnect the top case ribbon cable from its socket and redo the voltage reading on the power pads. If you then get the 3.42V you'll know that the top case is faulty. If you still don't get the right voltage then remove the logic board and check the magsafe DC in board and the main power fuse. When connecting or disconnecting anything on the logic board make sure the AC adapter and the battery are not powering on to the Macbook.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tyler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 875
