跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
Backlight but no display on LCD
I have an ipad 2 that may or may not have been dropped by a child the issue that I am having is that there is nothing being displayed on the ipad, but the backlight is coming on and the ipad is recognized by i tunes i will be disassembling tomorrow any tips if anyone has experienced this problem before would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hit the corner of the Ipad2 near the Headphone Jack, this trick worked for me and a few other people on the apple forum.
完成的
添加一条评论
3个答案
I would first check the LCD's connection to the logic board, and the cable's connection to the LCD. If the connections are good, then it's likely your LCD is bad. Be VERY careful when removing the digitizer. If it's not damaged, you don't want to break it when removing it to check the connection, or replace the LCD. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
There are 4 square like ic under the lcd connection
make sure you have all 4
这个答案有帮助吗?
得分 0
添加一条评论
Try hitting the top left-hand corner(headphone jack) a few times with your palm, it worked for me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alec 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,519
