跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Black screen after LCD replacement
My iPhone 3GS had a white screen with vertical stripes, so I have replaced the display. The power switch was broken, so I could not turn it off before changing it. I have also changed the rear case and the power switch. The repair went well, but now the display is completely black, with not backlight. The iPhone vibrates when the mute button is turned on and off, and it is recognized by iTunes. I checked that the connector #1 was correctly plugged. I've also tried to restore the iPhone but the screen is still black. Can this be fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
try the ribbon cables
这个答案有帮助吗?
得分 1
添加一条评论
If you changed the screen before turning it off, it is a good possibility you have blown the lcd
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your answer. Now that I have repaired the on/off button, how can I turn the iPhone off ? I have restored it, but since the LCD isn't working I am not sure in which state it is right now. It still vibrates, so I am sure it's on though.
完成的
添加一条评论
Hi Seb,
You have probably not connected the ribbon cables properly.
Corbin
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sébastien Maret 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 458
