跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
Why won't my iPod turn back on?
I just finished replacing the battery in my ipod touch 4G and it won't turn on. I've noticed that the board above the battery, below the front camera is slightly warm. No cables are ripped/broken. Anyone have an idea what could be wrong ? I also followed the ifixit guide on how to replace the battery to the word...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
5条评论
What was the original reason that you replaced the battery?
完成的
I replaced it because the battery life was very poor.
完成的
Will it not turn on if you plug it into the wall?
完成的
Nope. Wall or computer, it won't turn on.
完成的
The board is now cold. instead of warm.
完成的
添加一条评论
1个答案
已选择的解决方案
Here's a tutorial with pics that everyone has been requesting. I've used this method over a dozen times successfully. Good Luck!!
There are 3 small battery terminals (shown below). You only want to touch the one to the far right (circled below). Avoid touching the other 2 terminals!!
see the pics
http://guide-images.ifixit.net/igi/YiaQu...
http://guide-images.ifixit.net/igi/AnevP...
这个答案有帮助吗?
得分 1
3条评论:
thing you should always do b4 a screen replacement is make sure itunes detects it!
完成的
Thanks you sooo much!
This worked! ! ! ! My ipod is working again !
Only downside is that there's a small white line going across the bottom of my screen(Most likely has nothing to do with the battery ) buy HEY I'm not complaining ! :-)
Thanks again !
完成的
thats fantasic the white line im sure is a fault in the screen
完成的
添加一条评论
添加你的答案
Creativemagic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 277
