跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2397 个问题 查看全部
Why is my microphone still not working after dock replacement?
The last three weeks I've replaced mulitple parts in my phone. The mic was spotty at best during calls when I first started. Last week - after replacing the jack-connector the mic stopped working during calls completely.
I read different posts relating to this and came to the conclusion that I needed to replace the dock-connector. I got the parts today and started the process but after turning it back on the mic is still not working during calls. Everything else works perfectly, I can record sound, Shazaam does its normal magic but still nothing when I call someone up.
Is there any way this can be related to something different on the phone, or does anyone know of a solution to trick the iPhone into using the "mic-function" it uses for everything else? (I'm just waiting for a reason to start a jailbreak process so if this is it then that's perfect.)
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
最有帮助的答案
I have 3 solutions
this works on Iphone 4
i have tested all 3 of them, and have had success with all 3 solutions..
The Problem:
Iphone 4 lower microphone stops working.
recording video and memos works fine, but people cant hear me during calls.
just to clear things up for everyone...
when using video recording, memos or anthing else that can record your voice, the iphone is using the TOP MICROPHONE.
when calling/getting calls the iphone will be using the LOWER MICROPHONE.
When you put it on "Speaker" then the phone will use both.
Solution 1:
Change the Dock Connector
if that wont work... then....
Solution 2:
Click on this link, and follow the instructions, on how to fix the Compiler Chip.
iPhone audio problem: fixing an audio compiler chip fault
sounds and looks wierd...., but yes it works....
done it with multiple phones so far...
if solution 1 does not fix the problem, then solution 2 should help allot.....
should the problem still persist, then you might have a problem with your Home button.
See Solution 3 for more info
Solution 3:
Change the Home button.
this last solution was the problem solver for me... i had 7 dock connecters, new and from other broken phones i tested with.
in the end, the home button just gave up when i was swapping around, then i just replaced it, and Voila.... my microphone was working again, and my home button was working too :D
i cant really explain what really happend, but its my 4th iphone i have had these problems with, and all has been repaired with these 3 simple solutions...
i really hope it can help alot of people in here, with issues with iphone 4 microphones not working
这个答案有帮助吗?
得分 2
1条评论:
Another solution - The little grill thats between the body and mic can sometimes become blocked, i just came across one now that was blocked with some sort of oil, no sound would get through. After replacing that grill it worked perfectly.
完成的
添加一条评论
It sounds like there may be something wrong the microphone on the Power Sensor Cable, found at this link, rather than an issue with the Mic on the dock connector.
这个答案有帮助吗?
得分 1
添加一条评论
Hello.
I tried all 3 solutions, but mic still now working.
Got any other ideas?
The repair was on a 4s.
Thanks.
这个答案有帮助吗?
得分 0
添加一条评论
thanks bro...your solution no 2 was !@#$ awesome !
thanks
这个答案有帮助吗?
得分 0
添加一条评论
Mike the microphone on the power flex is for recording sound on videos and FaceTime bottom mic is for phone calls..
I have tryed solution 2 many a time and works but unsure how long it will last a reflow of that chip would fix it but is risky
这个答案有帮助吗?
得分 0
添加一条评论
Solution 2 rocks!!! Thanks a lot!!! You made my day.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Carl Alexander Kessen Sverdrup 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 9,491
