跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
iMac will not boot (even from extrnal drives) after file vault failed?
I currently have an iMac in for repair, which came in after the user turned on file vault but the machine crashed and he turned it off. After this the unit would not boot beyond the apple logo.
I removed the drive and attached it to another mac in order to turn file vault off assuming this would rectify the issue, however it did not.
At this point i connected a USB pen with recovery on it and attempted to boot, I've now tried 3 different recovery disks and an external boot disk none of which work. I've also tried booting the machine with the internal HD & optical drive disconnected.
If you attempt to boot in verbose mode it seems to stall at a different point each time.
I have also tried swapping the ram out to check this was not causing the issue.
Any idea's?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Depending on what version of OS-X you can have just the files or the entire HD volume protected. If the entire HD (boot volume) is encrypted you can't swap the HD to a different system as the CPU with in it has a different key burn't into it.
If you have disconnected the drive internally did you also disconnect the power connection(s) just incase the HD is pulling to much power (spindle motor frozen).
Did you try a new internal HD with a known working OS on it?
这个答案有帮助吗?
得分 1
3条评论:
Hi Dan,
Thank you for your response.
The machine is running mountain lion, so is on File vault 2
The whole volume was protected but having connect the drive to another machine i've managed to turn this off.
I've tried to boot both with the drive complete disconnected (no power connected) and with and known working drive connected internally and externally.
完成的
Do you have bootable OS-X DVD/CD with Snow Leopard or better yet an OS install CD/DVD? If you have, give that a try (with no HD's connected). Any difference?
完成的
No it's still the same with the snow leopard DVD unfortunately. However I'm not entirely sure whether this model would boot Snow Leopard under normal circumstances, some of the newer ones don't...
完成的
添加一条评论
This model should boot with SL without any problems. Early/Mid '12 onward systems can't boot with SL DVD.
So you likely have a problem with the storage side of the logic board or the power supply feeds for the drives.
Check the power first (easiest).
Did you use ESD protection when you worked on the system? You could have zapped something.
这个答案有帮助吗?
得分 1
6条评论:
Also try running AHT - Apple Hardware Test
完成的
Hi Dan,
Already checked the power to the drives, you can hear them spin up so i dont think it's related to that.
I always use ESD and the unit came in with this fault so i doubt that there has been a short on the board.
I think there must be an issue with one of the logic board chips responsible for the storage bus, as it wont boot from optical, usb or internal hd.
完成的
Did you run AHT (built-in) or try booting in safe mode?
完成的
Tried both cant get it to boot into either.
完成的
Then your right the logic board needs repair or replacing. Sorry ;-{
完成的
显示更多的1条评论
添加一条评论
添加你的答案
illPod 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 667
