跳转到主内容
PlayStation Vita(PSV)是PSP的后续机型,其具有更加强大的处理器与画面,添加了第二个类比摇杆。这款设备发售于2012年2月15日。
PS VITA CRASHED during Update
I have a PS VITA PCH-1003 model. It was crashed and I get to recovery menu and selected Update option. After downloading the 2.06 update when it was installing the update it turned off suddenly. Now when I turn it on the green screen will show up and says system update please wait and then the screen become black and the system is unresponsive to buttons. The PS button is not lit up. When I connect the charger the PS button become orange and then turn back off.
Any body know how to fix this.
Your help will be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
ok, lets see here. lets try getting it to recovery mode and see if that even works cause sounds like it might have bricked do to a corrupt system files.
press and hold “R” + Power + PS (PlayStation Button)
完成的
The recovery menu 4 option is disabled only one option is update
But it is already update now what I can do
完成的
添加一条评论
2个答案
once in recovery select "updater system software" from here you can redo your update if this fails for any reason you can always try "rebuild database" and as a last resort "restore system"
restore system brings your vita back to the base stock firmware when you bought it and will delete everything.
这个答案有帮助吗?
得分 0
1条评论:
I cant get in to the recovery mode when I turn it on the green update screen will come and disapear and PS button also is off then it stuck at this stage cant turn it on.
完成的
添加一条评论
sounds like your power button is stuck look up how to fix non working power and play station button. pretty easy fix. theirs a you tube video of what to do.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nazir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 3,410
