跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
hard drive compatibility
will a 5th-gen hard drive work in a 6th gen or vice versa?
seeing as they are the same connector I wondered.
same question for the lcd, could you switch out the ribbon cables and interchange them?
the headphone jacks are universal for the fifth and sixth gens, I know that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
For the "thin" version (80 GB, 120 GB, or new 160 GB), they should be interchangeable. There is a slight RPM difference, but it should still work. I do not have them available, or else I would test it to know for sure.
The LCD has a different width ribbon cable, but you mentioned switching out the ribbon cables. I've never tried this, so I'm not sure if you can pull it off...can't say one way or the other on that one.
Additionally, you can swap front cases between the two, and of course the button is interchangeable. I haven't tried the click wheel yet. These iPods are very touchy with the click wheel. If the cable is slightly off, the iPod will not start.
I hope this gets you started!
这个答案有帮助吗?
得分 4
1条评论:
yeah dude, thanks:)
those were mostly my thoughts on the matter, just wanted a second opinion.
完成的
添加一条评论
Old question I know, but I thought I'd post since this was one of the top results I got when I searched for 5th and 6th gen hard drive compatibility. I just installed a 6th gen 120GB in a 5th gen and it works just fine. Figured I would confirm it for anyone else that was wondering. The 120GB HDD makes a good replacement for the 80GB hard drive since replacement 80GB drives are hard to come by while the 120GB is common.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
tabormeister 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 30
总计 4,880
