跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 个问题 查看全部
问题已关闭
Mousepad-problem - clicks are not registered
Hello,
I have a 6 month old Late 2008 MacBook Pro 15" and about 4 months after purchase the mouse-pad developed a clicker-problem. A normal, standard (quick, not-too hard) click stopped being registered and required a much harder and somewhat lengthy click every time. Double-clicks started to be a bigger problem and general internet surfing began being annoying due to the repeated clicks required as and when I wanted to perform an action. I took the MacBook to an Apple-dealer who opened the back and apparently did something to the mouse-pad which made it function normally for a bout 3 days after which it reverted to being annoyingly difficult to use.
Has anyone out there encountered the same problem and can you help?
Many thanks in advance.
Vuk
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I know there is a screw on the opposite side of the track pad that when tightened prevents clicking. If you open up the bottom case and remove the battery it should be accessible. You'll need to use a T6 driver and all that needs to be done is to loosen it.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,747
