跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
How do you fix bluetooth?
My 16G 3G iPhone went kayaking with me...in the 'dry bag'. Apparently not so. It got little bit wet.And the whole phone went completely DEAD/bricked. I have seen little bit of moisture in the camera lens. After talking to rep @ ATT store he sugested to putt iPhone in 'bag of rice overnight' no kidding... it worked. but Bluetooth has not. Every time when I try to turn the Bluetooth on switch it's laboring for few seconds and then it turns it's self off. How do i fix it/
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I noticed you never got an answer to this. Are you still having this problem
完成的
添加一条评论
1个答案
已选择的解决方案
wow, this is almost a year old - anyway - there are many people with a similar problem.
the water most likely shortened some parts on the mainboard.
use the gps antenna guide (click) to disassemble the phone (you can stop at the point where the "board" comes out of the rear panel)
use some rubbing alcohol and a soft paintbrush (should have short hair) to clean the "greenish/white" areas (looks a little bit like mold).
be careful not to break anything on the "board" - let it dry and reassemble the phone.
wifi/bt and gps are using the same antenna - so look in the area of connector 6 - but the damages can be all over the "board".
good luck
这个答案有帮助吗?
得分 3
1条评论:
Yes, thank you for responding.
完成的
添加一条评论
添加你的答案
Milan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,274
