跳转到主内容
The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
23 个问题 查看全部
broken back glass over camera lens, droid Razr Maxx hd?
I have a broken back lens broken, need the part and how to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
After complete tear down of my Motorola droid RAZR M xt907, I used a heat gun to help loosen the glue on the back side of the camera glass. I then started pushing the glass from the inside outward with a pry tool. After peeling the remainder of the glass off and the glue tape I put the new glue tape on the phone and then the glass over the glue tape. The only thing you need to be careful with when using the heat gun is below the glass where the plastic coated cover where the phone serial numbers are.
Hope this helps.
thanks,
tstewart01fan
Update
Travis I got the replacement glass from www.etradersupply.com and here is the part number from their web site. Let me know if I can be of further assistance.
OEM Motorola Droid Razr M 4G LTE XT907 Battery Door Glass Lens
Item # ESMOT10184735
这个答案有帮助吗?
得分 0
1条评论:
This isn't an answer just a question for Paul, where did you get the replacement glass from?
完成的
添加一条评论
Where did you get the adhesive tape i broke my glass part so found the part via you on the site..but they don't have the tape...what kind should i use or get..thank you do much
这个答案有帮助吗?
得分 0
添加一条评论
The Tape was included when I bought one. They said they all come with the adhesive regardless of the add. Etradersupply.com was very helpful.
这个答案有帮助吗?
得分 0
添加一条评论
My back camera lense was busted. My friend made coffee and spilled it on my phone and now I have coffee under the lense. I got half of it out, I just can't reach the rest of it. Do you have any suggestions for getting it out?
这个答案有帮助吗?
得分 0
添加一条评论
My Motorola Droid Razr M's back camera glass is broken. I'm searching for the part first and then go for its replacement. Does somebody know where I can get this part from
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rdcarter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 7,135
