跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
SSD of early 2013 MBP Retina upgradable?
I got a early 2013 Retina MBP, 2.8GHz processor, 16G RAM(have the logic board replaced with the same model) and as it known to all, Sandisk SSD(512G) which lead to a annoying fan issue. Tried to replace the SSD with a Samsung 768G one, but it turned out the Mac cannot boot with the bigger size, Samsung SSD. I search the Q&A and found everybody said the SSD is upgradable. So how can my situation happened and anybody knows how to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
AFAIK the only 700+GB option is OEM at the time of order. In a while OWC may have SSD upgrades larger than 480GB (their current max) visit them and watch/ask. Until then, purchasing a display damaged 768GB unit might be your only other DIY option.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 2
7条评论:
What do you mean by purchasing a display damaged 768GB unit? I've already tried to replace it with a 768GB one but didn't boot at all.
完成的
So the case is 512GB cannot upgrad to 768GB right?
完成的
Apple said the upgrade would not be 3rd party compatible (they always say that - but at least at this time it's true, see my OWC link). You didn't say that you'd tried to swap out a 768GB SSD from a damaged '013 Retina (is that what you did?)
完成的
Oh, yeah, I forgot to say, it is a Apple customized Samsung 768GB SSD, used originally in RMBP, but the Mac couldn't boot.
完成的
Then the "drive" may be damaged too.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Yang Wang 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,544
