Temp sensor connector broken, where to solder? HF/E1, see picture
Dear,
Someway or another I have managed to broke the connector of the temp sensor on my macbook air A1237.
Now I want to repair it, and solder all the cables back to the connector, but I don't know where they should be soldered as it is not clear.
I have marked the cables on the board with 1,2,3 and 4.
Can someone please tell me where to solder them, see picture:
Thank you very much in advance for your help !
Kind regards,
Benwake
EDIT:
When you say "solder them back" what do you mean, see that the board where they are connected is not connected to the main board but until I can see from another angle I can't really help you very much.
由 John Laney 完成的
Hi,
Please check the image above.
I need to know where to connect the cables from the square part to the connector.
Thanks in advance
由 benwake 完成的
