跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
No power button, no signal
I replaced my friends display assembly following all the ifix it manual.
On turning the phone back on the power button would not work and still does not work, is it a dodgy contact somewhere?
The phone also states it is searching for signal although i am able to call out, receive calls and texts.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That's just a software issue - It'll go away after a while or after you reboot/turn airplane mode on/off. I think this issue started appearing after iOS 5.
You might inadvertently have broken the power button flex cable although you might be lucky it just isn't properly connected.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 221
