跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Pressure on screen switches ring/silent. What to replace?
When "vibrate ring switch" is on "ring", applying pressure to the upper left corner causes it to toggle between "ring" and "silent". When switch is on silent it does not happen. Occasionally it will happen without pressure on screen toggling back and forth by itself.
Took phone apart per instructions "to replace vibrate ring switch" just to check for loose connections or dust etc. but everything seemed fine. Do I need to replace the "vibrate ring switch" or the "headphone jack and volume control cable" ? Or is this something else?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I'm trying to avoid the "trial and error" method to save time and money. Hoping someone has experience or knowledge with this particular problem.
完成的
添加一条评论
2个答案
已选择的解决方案
try buy the part and simply plug in the new part while the old part is installed and see if you can replicate the fault, if you can not replicate the fault its safe to say go ahead and replace the old part.
这个答案有帮助吗?
得分 1
添加一条评论
I'd probably replace the volume/silent switch assembly, iFixit sell this part I think.
这个答案有帮助吗?
得分 0
1条评论:
Is this the part you are talking about?
"iPhone 4 Headphone Jack & Volume Control Cable"
[关联产品丢失或禁用: IF182-016]
Thanks!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 324
