跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
问题已关闭
Speaker problem, microphone don't works
Hy, i have a little problem. When i make a call in normal mode ( speaker off ) my microphone works but when i put it on (speaker on) my microhpone wont works. It's a little bit strange. When the speaker is on i can hear what that person said but he can hear me.
Thank you. Sorry for bad english.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Try to clean the switch for external Speaker, Use a little alcohol isopropyl for to clean.
and try again. However you must test the speaker with a DVOM , normally the resistance for coil speaker will be around 8ohms.Replace if the value is Out under the specification
God bless you
这个答案有帮助吗?
得分 1
1条评论:
@dr ing ernesto cuadra, where is the switch that needs to be cleaned?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 205
