跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Stuck in white screen with broken home button!?
Please help me! One week ago, i jailbroke my ipod and it got stuck in apple logo. and i cant restore it in itunes and also all the solutions i've found needs home button. but my home button is broken... then i tried to fix it by opening the screen of my ipod. only to find out that the home button (color gold inside) is already broken. so i cant fix it. then i tried to restore in itunes and it worked! but the problem is.... the screen is pure white. i tried 10 times restoring it but nothing happens. i jailbroke it again then restore but nothing happens. so my problem is how to get out of white screen with broken home button. and i think theres a wire in the screen that is not properly attached. (my thoughts). so what maybe the problem of this? and how will i fix it? tnx. godbless.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I would pop it open and reseat the LCD connector which you can find in the guide here for replacing the screen for your ipod. Most likely though you will also need to try a hard reset (holding both home button and power button for 10 seconds). So i would order a new home button flex cable and replace it while you are in there. Its very easy to replace and again, the guide here will show you how.
Hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
gizmo4sal3 what is a LCD connecter and a hard reset??????
完成的
添加一条评论
Same thing happened to my Iphone 6 last night with broken home button. You don't have to do any surgery to your iphone, ipod, or ipad. I would suggest you safe yourself the stress, money to repair or troubleshoot and your time. Just let the battery run down on whichever device you are using automatically, if so listen to music on it all day. And when you're charging your device it will continue working normally.
这个答案有帮助吗?
得分 0
1条评论:
how would you be able to listen to music , if you cant use your phone?
完成的
添加一条评论
This does not make since the phone is broke duhhh
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ivan Kennedy Puda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 7,686
