跳转到主内容
MacBook家族于2006年5月发布,替换了iBook来作为苹果消费级笔记本的产品线。
3786 个问题 查看全部
问题已关闭
MacBook 1,1 won't wake up when Lid is opened
today i changed the complete lid from a MacBook and now the MacBook won't wake up when the lid is opened - sleeping is no problem - the book falls asleep as soon as the lid is around 1" away from the battery connector/sleep switch - wut when i open it - nothing, i hav to press a button and then it comes back to life.
i used a magnet to test the switch - works without a problem - but the "point" is a little bit off - when i use the point where the magnet is in the lid - it only wakes up with a stronger magnet.
my ptoblem with that is only one thing - the both points are non changeable - can the magnet in the lid be "to weak"
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes magnets can become weaker. My first question is the alignment of the new lid correct? If so and there is room for the stronger magnet without causing other problems I would consider using the stronger magnet, but I would try to obtain another correct magnet first. Ralph
这个答案有帮助吗?
得分 1
2条评论:
The lid is in the right position
i have a few MacBooks, but no spare magnets - so i think i should try a tiny neodymium magnet to support the original one.
those small magnets would fit near the wifi antenna (and that way i won't have to disassemble everything)
完成的
nice solution +
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,326
