跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
metal pin in housing by the power switch - replacement methods?
Hello everyone.
I am having my back cover replaced to a bespoke one on my iphone 5.
the problem they are facing is this metal pin that is on the inside of the original housing.
this is not on the piece i have that im asking them to swap it with.
After some research i believe this is some sort of earthing pin and without this tiny little pin- the phone will not work.
Does anyone have any suggestions or tips to fix this or replace this pin
just to clarify
The new casing does not have this pin
The phone will not work without this
I have no spare pins
What has everyone else done?
your help - appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
最有帮助的答案
you will need 3 things, a small pair of side cutters, i mean small, a 6 inch screw driver and the small iphone pentalope screw driver.
to remove:
place aluminium casing on its back on a flat surface.
you can see the pin.
gently grip the pin using your small side cutters from the bottom of the pin
place your 6inch screw driver under the cutters and use the cutters as a falcrum
the pin will lift out gently.
to fit:
use your small pentelope screw driver and gently (using a screw motion) open the hole closer to the top, this will give the pin a bit more room and wont break the small casting when tapping the pin in.
tap the pin in gently until the top surface, this take in total around 1.5 minutes to do from start to finish.
good luck.
这个答案有帮助吗?
得分 2
1条评论:
who the !&&* has microscopic side cutters...?
完成的
添加一条评论
I had the same issue, though I don't know if its that important as they make it out to be, just use a sewing pin or something that fits in there, all I think it does is act as a hinge
这个答案有帮助吗?
得分 0
添加一条评论
It's just a structural support pin, No electrical function. Don't press the power switch too hard and nothing would happen.
If you really want to replace it, try extracting it from the original case and hammer it into the new one. You'll completely destroy the old one and risk wrecking the new one. But it is possible. I did it.
这个答案有帮助吗?
得分 0
添加一条评论
Look on eBay, they are sold on there for about $3 including shipping. Here are a few links...
http://www.ebay.com/itm/191243768536?ssP...
http://www.ebay.com/itm/191243769572?ssP...
http://www.ebay.com/itm/191243769575?ssP...
这个答案有帮助吗?
得分 0
添加一条评论
http://www.ipfix.dk/produkt/iphone-55s-o...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sally Kaur 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 7
总计 3,895
