跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
Why is my iPod touch screen unresponsive after replacement?
I have spent last night replacing my screen after I dropped it. When I finally finished, It worked fine but I didn't put it all back together. After doing so, it still worked but I hadn't put adhesive on yet. I went to sleep and when I woke up today, it worked fine until I moved the screen about 3/4 an inch. I think it might be the black digitizer cable that is causing problems. I took it apart, double checked, triple checked, and checked again that I didn't tear any wires. I don't know what else to do. I even restarted it. Is there some sort of software that will let me use my iPod Touch without actually having to install it on the iPod? (Meaning everything is done on my computer) The iDevice is also jailbroken.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
These digitizers are very, very fragile.. Plus, when you install the ipod 4 digi, you should rewrap the connector with the copper tape that was originally on the connector and wrapped around to the front of the logic board. I know that the stickum was probably bad, so what I do is use a small piece of double-sided 3m tape to reattach it.
If the connector is not taped in place properly, even moving the screen a bit could be enough to dislodge it. Sorry to say, but if I had to guess you are going to have to take it apart and double-check the digi to mb connection, and make sure it is tight.. If all this is done, then there is a possibility that you might have flexed the cable to the point to where it came loose at either end of the connections, and ruined it., Hope this is not the case, but I have done it more than once..
With all the ipods and iphones, handling the digitizer is extremely tedious and the more you handle them outside the case, the more likely you are to break something. These connectors and cables are not engineered for repeated maintenance. That is, they are set to work and stay where they are for the life of the product...
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,253
