跳转到主内容
Wine spill -- Laptop works but the keyboard doesn't
I spilled wine on my laptop keyboard, tried to clean up as much as I could and then let it dry for 3 days with the battery out.
As far as I can tell, everything on the laptop is working except the keyboard.
Can you tell me what I need to do to repair the broken keyboard? Do you think I need to replace the keyboard or the whole upper case?
thanks!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Here's a video on cleaning your keyboard. If that doesn't work you will probably have to replace it. Ralph
http://www.youtube.com/watch?v=jSpPlMdGv...
这个答案有帮助吗?
得分 3
5条评论:
This one's on the MacBook Air, not sure if they are the same
完成的
You are correct sir--here is a new one for MacBook. Ralph
http://www.takeitapart.net/archives/MacB...
完成的
完成的
Here's how to install it: MacBook Pro 15" Core 2 Duo Model A1211 Keyboard Replacement
Remember to tape down the motherboard connection with electrical tape. This cable coming loose is the most common problem on this repair.
完成的
awesome guys! thanks so much!
完成的
添加一条评论
添加你的答案
teddybaz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 6,323
