跳转到主内容
Magsafe Adaptor problems and battery
Hi there,
I have a problem with my Macbook pro 13", Mid 2010 :
When I plug my Magsafe adaptor into my macbook, it won't charge. Only when my mac is off or when my computer's closed.
I try to reset the SMC and other things but it's still not working...
So maybe you guys know how to fix it ?
The mac use to work perfectly before I restore it (was pretty slow).
By the way, they say that my battery's need to be check as well.
Maybe the both come together ?
Thanks for your help
Ben
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It sounds like the MacBook is drawing power to run the Mac but not charge the battery at the same time. Depending on the update, the battery may have been marginally good but is now being specced as bad by the software.
Here's a few ideas:
- Check the battery condition on the Battery menu icon.
- Check the Magsafe slot on the MacBook to see if there is any metallic debris. A magnet is there designed to hold the Magsafe plug, but it can pick up anything metal, as well, causing the plug to not seat well and even create a potential short.
-Try another Magsafe charger to see if it will charge the battery.
- If it doesn't then the battery may be at fault.
- If a new battery does not fix the issue, then the problem may be with the MacBook itself. Take it to an Apple store to get it checked out.
这个答案有帮助吗?
得分 1
2条评论:
完成的
Modern consumer-grade Lithium-ion packs are expected to last 300-500 complete discharge-charge cycles (However, abuse, like completely draining the battery multiple times will drastically reduce those numbers). I do not know how you use your system, but having to replace a battery under two years' of "normal" use would not be uncommon.
完成的
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 9
总计 336
