跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36478 个问题 查看全部
问题已关闭
Rear panel not fitting after repair - iPhone 4
Hi
I have just replaced the home button and ear piece on my iphone 4. Put everything back together quite easily but the rear panel wont slide on anymore, the battery appears to be higher than the frame. I have managed to force the rear panel only so I can use the phone but its not secured in the top right corner near the vibrator.
What could be the issue? There is nothing obstructing the battery, everything is in place perfectly and working correctly. Could I have done something to the battery to make it bulge? I made sure the wifi antenna is correctly in place so that doesn't appear to be obstructing the panel, it just appears to be the battery.
Any help would be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hi, the battery in the iphone is flexible you can push on any part of it that appears to obstructthe rear pannel. it wont take very much pressure to get it back in shape.
I would also suggest that you check there are no screws jutting out.
if this helps you please rate my answer . thanks
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 220
