跳转到主内容
加入维修社区 - 创建账户
第三代配备 Wi-Fi 的 iPad,于 2012 年 3 月 16 日发布。型号A1416。维修需要加热并小心撬开它。
Part of the screen does not work
After replacing digitizer the top (assuming home button=bottom) part (about 0.85 inch) for left to right does not respond. What could be the reason? Looks like it is exactly 1/9 of the screen maybe that could be a clue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Were you replacing the digitizer because it cracked, or because of a similar issue on the original digitzier? It could be a damaged connection that caused your initial problem.
Where are you buying the digitizer from? That could make a difference.
完成的
添加一条评论
2个答案
bad digitizer.. This is common, right out of the box.. 20 percent are bad, and on some, I have even had the connectors come out separate from the digitizer (yeah it was broken off).. don't doubt what your first inclination is, and don't make it any harder than it is..
这个答案有帮助吗?
得分 0
2条评论:
Tried another digitizer with the same result. still could be the digitzier (down to 4%). or maybe something else. do you know of a source that offers good pretested digitizers?
完成的
Ifixit and MobileDefenders offer great parts with excellent QA.
完成的
添加一条评论
The left 10% wouldn't work for me first time. Went back and checked the ribbon connectors and managed to get it in another .1mm and also one of the plastic clips needed sliding in a bit after clipping it down. Perfect after that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
boazparran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 822
