跳转到主内容
MacBook Pro 13寸显示器版本
9740 个问题 查看全部
Why does my 13" MacBook Pro freeze temporarily?
it freezes often & for only about 30-45 seconds, then releases & is fine. it froze after i typed the first "i" in this description than what ever i typed after that, appeared in about 30 sec--this is just one example--sometimes i get the spinning wheel & sometimes i don't.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Could be the first sign of a failing hard drive.
这个答案有帮助吗?
得分 0
1条评论:
i think you are right. that's what i was thinking as well.
完成的
添加一条评论
I had this same problem. I shouldn't say 'had' because I still do.
I tried new RAM and a new HARD DRIVE (Switched to a 256 GB SSD) and, if anything, it has gotten worse. Now it locks up for 10-20 minutes, I end up just force powering it down and booting up again (SSD makes this a lot less painful than a standard drive).
I've read somewhere that it could be a faulty hard drive cable...I may try that next.
这个答案有帮助吗?
得分 0
添加一条评论
It's very common for the hard drive cable to go bad on those. I would start there. Much cheaper than a hard drive.
这个答案有帮助吗?
得分 0
添加一条评论
I think it may actually be the battery being old and expanding a bit causing unwanted pressure on the computer which causes issues.
I switched battery on mine and it seemed to solve it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
david quinn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 537
