跳转到主内容
加入维修社区 - 创建账户
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
Hold switch doesn't works
Since I replaced the broken hard disk, my iPod is locked and shows the padlock icon on the screen. It works connected on the computer and the car adapter, but obviously the clik wheel doesn't responds. I've tried all the common recomendations -reboot, restore, upgrade firmware- and nothing happens.
I replaced the headphone jack cable -which had broken when changed the disk- and today I tried to fix it changing the headphone jack and headphone jack bracket. Same results.
I have a new iPod Touch but I want to preserve the old one because I usually use in the car. I can hear my music, but imagine the situation: only one option, reproduce the songs in alphabetically, from a to z!
Can someone help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks Wes for your answer, but I think that's not my situation. I put again the headphone cable and nothing happens.
But I observed something courious: the central button turns on the iPod also with the hold switch in the locked position. But still locked with the padlock on the screen...
完成的
添加一条评论
1个答案
已选择的解决方案
Hi, I had a situation similar to yours. I purchased an 4th generation photo iPod from an individual that was "stuck" in the
lock position on the LED screen. I openned it up and found that the headphone cable has been put back up-side down,(not backwards).
I flipped in over and the lock worked perfectly. I don't know
if this is your situation but it worked for me. Good Luck.
这个答案有帮助吗?
得分 1
1条评论:
Perfect. My headphone plug was just loose after I put a new battery in. I took the case off, re-plugged it in and the "lock" icon went away. Works perfect now. Thank you!
完成的
添加一条评论
添加你的答案
rogerangela 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 1,666
