跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
White screen after drop
I dropped my iPod and now my screen is white. The iPod still makes sounds, gives me notifications, and the buttons do what they're supposed to.. I can even unlock it by sliding my finger across it, but my screen it just white. I can't see what I'm doing.. Help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi
If youve dropped it then its likely the screen has gone faulty and will need replacing.
There are guides on ifixit to help you replace the screen but you do so at your own risk as its not easy.
You can also buy the part from ifixit
Regards
Update
Hi you can pick up a replacement screen for about $30 from ifixit found here
iPod 4G Display
there are plenty of guideas around to assist, but i do warn you its quite difficult if youve never done it before
Regards
iPod 4G Display图片
产品
iPod 4G Display
$29.99
这个答案有帮助吗?
得分 0
2条评论:
Thank you! Do you have any idea of how much that will cost me?
完成的
About $30 probably if not less
完成的
添加一条评论
最有帮助的答案
Hello! It may be the LCD is damaged or the connector may have just popped loose. I would follow the guide here to open the ipod up and just reseat the connector first. May save some money. If that doesnt do the trick than I would order a replacement screen and replace. Not terribly difficult to do. The screens usually run about $15-$20 online.
Hope this helps
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lace 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,947
