跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
iMac Late 2006 won't power up
Installed SSD recently and everything worked for a week. This morning, I was unable to power on the machine. Disassembled the machine and peeled back the EMI cover. The first LED light came on as soon as connected to the power source and both fans jittered. When the power button is pressed, the second LED came on and stayed on. However, nothing happens. The third LED light never come on. Kept holding down the power button and the second LED went off. Any advice would be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Sounds like a bad power supply. Also examine the 24 capacitors for swelling and/or corrosion.
这个答案有帮助吗?
得分 1
3条评论:
Thanks mayer. Will remove the power supply and look at it today. The fact that the first LED stays on solid when iMac is connected to the power source does not necessary indicate that the power supply is good?
完成的
Almost all the power supplies 20 to 1 have had the the first green light on. All that indicates is that there is trickle power getting to the unit.
完成的
Removed the power supply and examined it; noted 5 capacitors on the board. No swellings or corrosions were noted. Is there ways to test the PS to determine if it is good or bad?
完成的
添加一条评论
This is an all in one desktop unit.
这个答案有帮助吗?
得分 0
1条评论:
and? Tell us something we didn't know.
完成的
添加一条评论
添加你的答案
Shane 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 882
