跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 个问题 查看全部
问题已关闭
"Do Not Remove" Sticker
Battery replacement went fine. Works perfectly...but what about that "Do Not Remove" sticker under connection "6". Does it serve any purpose? I destroyed it getting off to uncover the screw underneath. Is it an Apple Police sticker? Should I go back and replace it with something like a square of electrical tape?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
Don't worry, probably kind of warranty void. But if you change the battery you are probably not under warranty anyway!
In case you had a metallic part or other conductive material over it, you could put another piece of tape for security but it look it is the battery plastic envelope just over so no risk.
Picture from the iPhone 3GS Teardown for reference:
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 1,039
