跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
问题已关闭
Power Button does not work after flexcabel change
first off all i'm from switzerland. sorry for my bad english. 2 months after guarante my power button get stucked. it doesn't made click anymore. so i changed the flex cable including sensor. after the repair the power button clicked, but didn't work. the sensor didn't worked either. then i bought another flex cabel incl. sensor (a better quality).
and now the sensor works but the power button doesn't. It clicks but there is no reaction.
does anybody had the same problem?
im thankfull for every answer.
regards from zürich
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It seems that you have to change it again...
[关联产品丢失或禁用: IF182-004]
iPhone 4 Power & Lock Button Replacement
iPhone 4 Power & Sensor Cable Replacement
If this answer was helpful please remember to mark it accepted.
iPhone 4 Power & Lock Button图片
指南
难度:
困难
15 - 30 minutes
iPhone 4 Power & Sensor Cable图片
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 1
5条评论:
sorry my mistake. i meant of course the power button (not home button). same answer? thx in advance
完成的
Answer corrected... ;-)
完成的
hello xgonin
thx for your update.
i replaced it now for the 3rd time.
and the power button works now. but..!! :(
the sensor works now backwards.. when i put my hand on it, the display appears and when i put my hands away, the display disappears.
do you have a solution? thx in advance. regards from zürich
完成的
i repaired the phone for the 4th time with another new flexcable. now its working well. failure was 3 not working felxcable. thx for support
完成的
you're welcome ! ;-)
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,177
