跳转到主内容
No audio output detected
Hi,
I have a big problem with my macbook pro late 2011 with mac os 10.7.5. The problem is : no audio device detected.
So i did all possible solutions found in forums but with no result.
If any one had the same problem and he found solution plz shar.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
You could try a USB Audio Dongle..(adaptor). USB audio runs on different chips... if the adaptor is discovered it would have line in/out ports... BTW some of the adaptors are also microphones.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
2条评论:
Thank's for your answer.
But i'd like to know if its a driver problem or material problem.
完成的
Sorry to delay replying - was supposed to have been notified you commented. Either I missed it, or, it's still in the aethernet.. anyway must be hardware if all the software fixes failed. There are no software fixes for hardware problems.
完成的
添加一条评论
添加你的答案
Donili 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 907
