跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Why won't the small screws on the outside cover come out?
One of the screws at the bottom of my iPhone won't come out. Basically the head has been distorted to the point no screw driver will bite into it enough to remove it from the body of the iPhone so I can do a screen replacement. It also appears wedged in the hole as if it was cross threaded when it came from Apple or else it was jarred making it crooked from being dropped.
Anyone have any ideas?
I considered bore-ing through the screw with a small drill bit. Similar idea to tapping when you break a bolt or something off on a car.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks for accepting my answer...
完成的
添加一条评论
1个答案
已选择的解决方案
There is so many different procedures....
Take a look at these links :
Remove a stripped screw
The 12 best ways to remove stripped screws
Or use the Precision Screw Extractor Set. Here's where to get a set:
If this answer was helpful please remember to mark it accepted.
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm.图片
产品
$24.99
这个答案有帮助吗?
得分 0
1条评论:
Your welcome! I can't wait to try your suggestions!
完成的
添加一条评论
添加你的答案
Angeline 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 10,244
