跳转到主内容
问题已关闭
Can I install parts from a MB unibody into MBP unibody? (A1278)
It was really confusing when I searched for the magsafe and logic boards for A1278 MBP 13. Both the MB and MBP unibodys carry the A1278 model #.
I figured since both have the same model #, the magsafe board from regular MB unibody to MBPro unibody should fit...from the pictures they looked identical. Can someone tell if this is possible? Also can I do the same with logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
I have all this info charted out, but don't have it with me. I'll be sure to answer tomorrow. Sorry!
完成的
Thank you ben, where can I get chart from?
完成的
添加一条评论
2个答案
已选择的解决方案
Sorry for the delay!
In terms of the model numbers, Apple sometimes gives very different machines the same model number, for some unknown reason. Unfortunately, having the same model number doesn't automatically indicate compatibility.
For the magsafe boards, they are the same form factor, but have different part numbers printed on them. I haven't personally tried to see if they are compatible in reality, but it could be a situation similar to the original MacBooks (the magsafe ports have different part numbers, but are interchangeable).
For the logic boards, the MBP 13" board is shorter and has different ports, which would also necessitate a new upper case. That gets very expensive!
In summary, the magsafe will fit, but it's your call whether you want to try it or not. The logic board is not interchangeable.
Good luck!
这个答案有帮助吗?
得分 1
2条评论:
Thank you Ben. Got an answer from an ebay seller, said it can work both ways, and the pricing is higher for MBP magsafe compared to a MB magesafe. :S
完成的
+1 Ralph
完成的
添加一条评论
最有帮助的答案
Hi, Looking at the Apple part numbers for the two magsafe boards they are different. The MacBook Unibody has a part number of 661-4947 while the MacBook Unibody Pro has a part number of 661-5235. Because the part numbers are different I would be hesitant to substitute them. Ralph
这个答案有帮助吗?
得分 1
2条评论:
Wait for Ben's answer to be sure. Ralph
完成的
yea they are different part #s. I asked an ebay seller he said the it can work on either. Will wait for Ben's answer just to be safe.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,658
