跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
问题已关闭
Non working backlight after battery replacement
Hi,
Having replaced the battery in my 16G everything workes absolutely fine except the backlight.
Tilting the %@$& iPod towards a light shows everything that I expected to see, and the device reacts to being touched over the whole of the screen.
Nope resetting the settings dosn't work.
I suspect an issue with the ribbon cable connectors or even the ribbon cables but am unsure what the solution is.
Rob...
PS a bit sad that you censor the word d.a.m.n.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It could be something as simple as a poorly seated connector. I would recommend detaching your display and then re-seating the connection. If this does not solve the problem, it is possible that your LCD was 'zapped' during installation by the logic board, in which case you would need to replace the iPod Touch 1st Generation Display.
这个答案有帮助吗?
得分 1
4条评论:
Thanks for your reply.
I have reseated the connectors several times without joy.
Zapping the display, it's pretty unlikely as I was being nice regarding the antistatic precautions (mat and wristband) as I work with a lot of embedded microprocessors.
I actually suspect the black ribbon cable which runs (diagonally) under the battery as it as actually attached to the glue pad holding the battery down & there is some damage to the outside edge.
I'm hoping that this cable is replaceable as I don't want to go to the expense of buying a new display for the sake of a cable.
完成的
That display cable is not sold separately and is only available as part of the LCD.
完成的
Indeed I have sourced a reasonably priced replacement, but I will have the conductive paint out at the weekend as it seems to be a hairline crack causing the issues (and once in place should hold till the next battery change)
Thanks a million
完成的
Good luck!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 1,955
