跳转到主内容
加入维修社区 - 创建账户
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
Crashes when unplugged or plugged-in.
I have a 17" 1.33 PowerBook. I have no problems charging or booting, or running, but whenever I unplug the charger the computer will turn off. Or, if I boot when unplugged, and then plug in the charger, the computer will also turn off. It always happens just as the charger is about to disconnect (about 1/4 of the way inserted). With the computer off and the top-case removed, if I insert the charger plug 1/4 way into the DC-in board the PRAM battery makes a soft, high-pitched noise. I've replace both the DC-in and the PRAM battery, but nothing has changed this problem.
I'm at a loss. Could it be the charger? or the DC in board, the PRAM? or a short somewhere else? I don't want to buy a lot of new parts if it's most likely a short in the motherboard.
Any help would be appreciated, thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Run the PMU reset and the PRAM reset and see if that helps. Ralph
http://support.apple.com/kb/HT1431
http://support.apple.com/kb/HT1379
这个答案有帮助吗?
得分 1
2条评论:
Have reset both in the past with no effect, and did it again, still with no effect. Have tried 2 different batteries, with the same result.
由完成的
If you can borrow another charger try that to a least eliminate a cause. Ralph
由完成的
添加一条评论
最有帮助的答案
Try connecting/disconnecting the power at the outlet. What happens when you do that?
这个答案有帮助吗?
得分 1
1条评论:
When I unplug from the outlet everything is fine. But even when unplugged, if i unplug from the computer, total immediate shutdown.
由完成的
添加一条评论
Wiggle the power connector at the laptop end a little bit while its running. This may help you narrow down which is faulty, the power connector on your laptop or the end of the power cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alexbrooks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 20
All Time: 1,588
