跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Power button lost spring action
I tried many times to re-seat the power button but unable to make it click with spring action. I made sure that liigle rectagular tape it is in place and not too tighten the screws as suggested in other releasted questions. Still unable to make it click. HELP! ...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Solved: It turned out that the little rectangular tape (spacer) is not thick enough to push the power button out after tighten up the 2 screws that hold both on/off button and contact point. I added a couple of layers of electric tape on top of the original little rectangular tape behind the button. Problem is solved.
ifixit.com step 17 described the functionality of this little rectangular tape as "When replacing, check the protrusion of the switch. There is a small plastic spacer adhered to the inside of button which may come off with cleaning. Without a spacer, the button may not protrude enough to be depressed. If lost, it can be replaced with a suitable thickness of stiff plastic (eg shirt box lid)."
完成的
添加一条评论
1个答案
已选择的解决方案
This usually means the contact point on the ribbon cable has failed and will need to be replaced, here are instructions to replace it and I caution you, it takes Patience, but not that tough, [无效指南链接], good luck, If this answer was helpful please remember to mark it accepted
这个答案有帮助吗?
得分 0
2条评论:
Thanks but ... the power button is still working when push hard on it with finger nail since the button itself is almost flat with the back cover. I can not make it protruce to 1mm as my other 3GS phone. It just does not spring back with clicking feel.
What make to button spring back? The contact point or the metal loop come with the button? What is the function of the little rectangular tape? Serve as the spacer to make the button protruce out? Does it need to be loosen up or can be glued fix to the button itself?
完成的
The Ribbon cable has a metal contact point on it that has a spring action to push your button back up, so my answer above is still what I think you need to do to fix your problem, good luck.
完成的
添加一条评论
添加你的答案
hungtphan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 886
