跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
No service after auto/manual searching for signal
I cannot get a signal on my iPhone 4s, ios 6.01 baseband 3.0.04.
If I try to manualy sellect carrier, it searches for the available carriers, finds them and when I select one I get no service. Tried calling emergency number without a sim but that failed also, it should have worked. What's broken, where to look first?
Thank you all for reading this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
I would start with the obvious and cheapest, the cellular antenna, make sure its plugged in correctly to your motherboard, if it is then I would replace it, iPhone 4S Cellular Antenna Replacement also has your water damage decals turned pink, (water damage) if so treat it for that, 修复iPhone 的进水故障 , good luck.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 4S Cellular Antenna图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried to set the date and time manually? If you take out the battery on the iPhone (iOS 6.xx) the date will be 1970.. :p
When you have set the date and time, remove the sim card and put it back in.. This should work :)
(you kan also connect the phone to the WiFi to automatically set date and time. Do the same with the sim card, when the time is right :) )
这个答案有帮助吗?
得分 1
添加一条评论
as long as all the connectors are connected properly.
I would try the Wi-Fi conect first . the date & time should update & give you signal back.
if this helps please mark as accepted
这个答案有帮助吗?
得分 0
添加一条评论
I'm having the same prob no signal and I have replaced the cellular an tenner and mad sure it's connected/plugged in properly. I'm not to sure wot ya mean with this date thing as when I take my battery out and refit it the date and time set correctly ( not to 1970 ) is there any other plug and play parts I should try b4 making the assumption it's a blue inducter coil problem??
这个答案有帮助吗?
得分 0
1条评论:
Do you get the network when searching manualy? The weird thing is I do but when sellecting one, no service!
完成的
添加一条评论
添加你的答案
daian catalin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,736
